fuel pump humming all the time
Old Jul 3, 2003 | 07:52 PM
ddmcamaro's Avatar
Default fuel pump humming all the time
the fuel pump on my 98Z28 is humming all the time now, so i am assuming it is going bad. the car is completely stock so i am not looking to upgrade. any suggestions on what brand and where to go to get a replacement. checked a couple of part stores online catalog and they didn't carry one. and also, how hard is it to change a fuel pump?
Old Jul 3, 2003 | 08:02 PM
ddmcamaro's Avatar
Default Re: fuel pump humming all the time
after posting this, i have found in other threads where people have cut a hole in the trunk to get the fuel pump, how do you know where to cut?
Old Jul 6, 2003 | 03:55 AM
blown 346's Avatar
Fuel pumps do usually have a humming noise from them. I would not cut a hole in your trunk to yank out a fuel pump!!! Drop the tank and replace it if you want but dont go hackin away at your car. My fuel pump humm's,buzz's and it's fine. With every Chevy i have seen you can hear the fuel pump working, I would make sure the pump is going to crap first before you go and replace it.
Old Jul 6, 2003 | 08:30 AM
ddmcamaro's Avatar
you could always hear the pump humming, it was just alot louder the other day. you could actually here it while driving. today when i drove the car it sounded normal, could here the pump right at start up but then went away so i'm not worried about it. didn't really want to cut up my car anyway. thanks
Old Jul 6, 2003 | 09:43 AM
Chris99WS6PWTMET's Avatar
You will after you drop the tank a few times. Save 3 hours and cut a hole.
Old Jul 17, 2003 | 08:17 PM
smoknta's Avatar
I wouldnt suggest cutting a hole in your car. Its not that hard to drop the tank. I also wouldnt suggest changing the pump until you see an actual problem, not just a little extra hum.
