Need advice on intank and inline pumps for my application...
I like the TREX and have seen it work great on other cars but it is so LOUD that I may not use it. ANy thoughts? I will use stock injectors for now (unless dyno info points to needing bigger ones). I will probably get 30 lb SVO's when I need to replace them. Will an injector swap need tuning, and if so, can it be done just with computer or would MTI need whole car to run on dyno?
Thanks,
SDB
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
SDB
A single in-tank system will support upwards of 600RWHP as More Performance has proven with our prototype systems.
There is the option of twin in-line Walbro GSL392 pumps and a Racetronix harness which will support upwards of 1000HP using -8 lines.
>WEB SITE<
P.S.,
What injectors do yu think I would nedd with my described setup?
you could call speed inc and they will put together all the parts you need for it (thats what i did)
i will be documenting my install of two walbros and external regolator for 99+ cars.
mighty mouse has some good pics on his 98 car, which i am doing similar.
SDB
