Looking for some help with my fuel system
Just wondering what kind of fuel system i should start to consider putting in my car. I want a system that will support 150 wet shot at max and i probably wont be that much higher for the next 10 years.
I looked at the Racetronix setup for 229.99, apparently the performance set up because it comes with harness, ground, and boost a pump. What about injector size?
600 x 1/2
----------- = 30 lb/hr is that right? Do you think i should be making about 600 crank with this setup
8 x .8
Im bolt-on stalled A4 if it matters.
Thanks
