48 lb injectors?
Old Feb 16, 2008 | 11:29 PM
dredoggy's Avatar
Question 48 lb injectors?
98 ls1 ws6 anyone know if the new racetronix 48 lb injectors are any good? or racetronix anything for that matter i am going w/sts turbo want about 550whp will these be enough? also is their fuel system any good? haven really read anything bad on them but just thought id ask before purchasing, i have also read go with 60 #r's insted of 42 #r's any highly recomened brand name's anyone leans twards? any help would be super
Old Feb 17, 2008 | 12:22 AM
sworaz's Avatar
Racetronix makes good injectors. I would do a little searching about the size injectors per boost. At first thought, I would probably go with 60's, it will give you room to grow.
Good luck.
Old Feb 17, 2008 | 01:45 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I would go straight to 60s.
Old Feb 17, 2008 | 08:52 AM
SUPERBOOST's Avatar
RC ENGINEERING has a chart you can put all your info in and it will tell you what size injector you need,should get you in the ballpark.
Old Feb 17, 2008 | 08:54 AM
lmt0705's Avatar
go with 60s, still very easy to tune with and when you go bigger, (and trust me eventually you will) you wont have to spend another 400+ on injectors again
Old Feb 17, 2008 | 11:31 AM
kidcamaro98's Avatar
I got some flow balanced Mototron 48lb ls1's if your interested....I need to get rid of them to upgrade (maxed out at 13psi)
Old Feb 17, 2008 | 07:16 PM
dredoggy's Avatar
thanks for your help i think i will go with the 60# thanks for the offer on the 48 # ill keep those in mind but im sure i will go big or go home hp is addictive !i would go w/racetronix injectors but next size up is 79# .how are the mototrons? any one use them? is the racetronix fuel system upgrade any good?
Old Feb 17, 2008 | 07:19 PM
dredoggy's Avatar
sweet video btw your car looks like it gets busy did you race the jeep? and if i want those injectors how much?
Old Feb 19, 2008 | 01:46 AM
JoePZ28's Avatar
I have some brand new Mototron 60#s for sale. PM me.
Old Feb 19, 2008 | 09:07 PM
ZL1Killa's Avatar
DO NOT GO WITH 60#ers! you will idle at 11.0 AFR .... you will need a fuel pressure regulator so your fuel pressure will drop and ...yadda...yadda to try and control the injectors. with 550whp you will be fine with 46#ers or 48#ers....because most of these injectors are rated at 43.5psi; while our systems run at 58psi
if ya want any help just pm me. i have some excel sheets and would be glad to email/post them.
Old Feb 21, 2008 | 09:22 PM
mycar2fast's Avatar
i dunno why you keep wanting 60r's you do not need them!!! but if u insist on buying 60er's you can get some at zzperformance brandnew flomatched lucas 60's for 320 bucks
Old Feb 21, 2008 | 09:52 PM
BigJls1's Avatar
Bro thats for 6. Ls1's need 8 .
racetronics price shipped to your door 450.
Old Feb 24, 2008 | 12:35 AM
blownbird355's Avatar
I maxed my 48's at 460 rwhp through an auto.
Old Mar 2, 2008 | 05:10 PM
dredoggy's Avatar
so many different choices it is hard to decide i did the rc enginering and it said 40.59lbs/hr so not sure if my 32# will do the trick and that rating from them was at 500 hp and if you maxed your 48 out at 460rwhp still not sure on this
Old Mar 2, 2008 | 07:39 PM
ZL1Killa's Avatar
are you spraying or something?
Old Mar 2, 2008 | 07:40 PM
ZL1Killa's Avatar
please check out www.rceng.com and read and play with their technical page and injectors.
http://www.rceng.com/technical.aspx
Old Mar 2, 2008 | 08:56 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Excellent comment.... you would not believe how many people I try to help with respect to future upgrades & often I'm told "I'm not changing anything else after I get this together". Then a year later I get another call asking about an upgrade. This has held true in relation to injectors, fuel systems & superchargers.
The 60's are easy to tune & will serve you well into the 800+rwhp range.
As far as Racetronix, their products are of very high quality & I would be glad to help you out with anything you may need.
Old Mar 3, 2008 | 07:34 AM
ZL1Killa's Avatar
the problem with 60#ers is below a certain range or if you don't have a fuel pressure regulator.. then you idle at 11:1 AFR RICH AS CRAP. so if you don't plan on changing up to 800hp you don't need them
48# or even 55# injectors from racetronix will serve your purpose much better and even if you do build a 427 twin turbo setup and pass 800HP someone will buy those injectors off of your hands for practically what you paid for them. and you can then upgrade.
Old Mar 3, 2008 | 07:06 PM
LS1TECH Sponsor
Trust me, with a proper tune, the 60's will idle like stock. I've put them in stock LS1 motors & they work fine.
Old Jan 2, 2009 | 09:47 PM
Supercharged LT1
