just put in 60lb injectors few questions
On the new injectors i removed the bottom oring to put a different oring on that came with a ls2 manifold kit with injectors. Will that really seal in the boost from a supercharger? just seems like not alot holding them in and sealing it. Why are the 60lbs injectors longer and need to move the fuel rail up with alum spacers?
Whats the stock fuel pressure? How high of a pressure can the 60lb take.
Coal Mining Director
Make sure the retro kit is installed properly...fuel on a hot engine = fire.
EV1 style injectors are longer by design as compared to an EV6.
60lb Mototron Siemens injectors work well into the 80's in psi...I ran mine up to 87psi without problems.
I'd set the base pressure at 58psi.
