98 walbro pump install
Old May 4, 2008 | 11:48 PM
spaz1's Avatar
I'm definately going to do it this way.10mins of cutting vs 4hrs of work.
Old May 5, 2008 | 12:35 AM
RoDan's Avatar
was the wire you used Teflon jacketed? the Teflon jacketed wire is much more resistant to fuel than standard pvc jacketed wire. Other wise that install looks good man, rock n roll!
Old Oct 11, 2008 | 09:20 AM
98Camarod's Avatar
There isn't a worry about not having the fpr filtered and it doesn't have to go down to the level of the sock?
Old Oct 11, 2008 | 02:13 PM
Mean Green z28's Avatar
nope just tie it up to a side The only reason the stock setups have the return redirected back to the sock is 'cos it's already filtered though the sock and the filter and so they dump it right back at the pump to keep the sock clean in the long run.
Old Oct 11, 2008 | 02:45 PM
Black FormulaLs1's Avatar
is a straight pain in the *** unless you notch like SPAZ1 said..i know i am going to after i drop the tank again..i am not cutting on top of my fuel tank if its leakin..ya know?
Old Oct 11, 2008 | 02:51 PM
spaz1's Avatar
I used the kit from racetronix... I still had to drop the tank down a bit to get the lines off and it was really hard to get the pump unit back into the tank through the hole. Now my fuel gauge doesn't go to full anymore. I am going to pull it apart again when I put it away for winter.
Old Oct 11, 2008 | 04:18 PM
98Camarod's Avatar
It was easy to get the pump out. I just took the float off and the pump slid right out.
Old May 29, 2009 | 01:33 PM
DGraboyes
Guest
Posts: n/a
this should be a sticky since the 98 people are left in the dark when it comes to fuel pumps
and the 99+ guys got their own sticky and discussion
helped me a hell of a lot!
Old May 30, 2009 | 06:04 AM
redbird555's Avatar
Mines an 01 so it doesnt have the baffles. I bought the racetronix pump only for $150 (I didnt see the need for the harness) and its been great especially since it fits in without modifying the bucket its been good for about 6 months now.
Old May 30, 2009 | 10:59 PM
1fast98's Avatar
Default sock?
hey what sock fits the 255 pump? the 98 sock is way to small.
Old May 31, 2009 | 08:52 AM
DrkPhx's Avatar
Why are 98's left in the dark? Racetronix makes a fuel pump kit specifically for 98's. It's a straight forward install. The only thing that really sucks is the metal tank itself is not as easy to move around compared to the plastic tank when you drop it.
Old May 31, 2009 | 10:25 AM
  #32
spaz1's Avatar
I just pulled the piece out of the sock and it fit right on.
I had a really hard time getting the pump back in on my 98 it is mounted on a springloaded leaver and It didn't want to go down the weird shape just at a weird angle.
