fuel sender maybe?
Old Feb 27, 2008 | 09:51 PM
Gregorya24's Avatar
Default fuel sender maybe?
sometimes my gas gauge works and sometime it just stays below e and i can have full tank of gas or it takes a really long time to come up when i have gas in the car....any inputs?
Old Feb 28, 2008 | 01:09 PM
Gregorya24's Avatar
no one?
Old Feb 28, 2008 | 01:35 PM
ss1's Avatar
ss1
Possibly the sending unit in the tank. I bought a used bucket assembly for a double pump system and a couple of the tiny tabs on the resistor part were missing. I guess its a possibility.
Old Feb 29, 2008 | 02:05 AM
Juiced2000SS's Avatar
I also think the fluxuating gas guage is caused by those little metal tabs on the level sender. I have replaced a couple in different GM vehicles with this issue.
Old Feb 29, 2008 | 11:27 AM
peterock98's Avatar
Another board member said check the pcm wires.
Old Feb 20, 2012 | 11:22 AM
mikh338's Avatar
bringing this back from the dead because I have having this same issue. I have an aftermarket fuel pump installed(previous owner) and like the OP said, my guage is also all over no matter how much gas is in it. i have the same exact issue as OP. The previous owner cut a trap door to get to it so I dont have to drop tank but if anyone can help me out please this is driving me nuts!!
Old Feb 20, 2012 | 07:56 PM
Mr. Fuel Pump's Avatar
It is likely the level sensor card or wiper finger contacts. A float travels up and down with the level of gas and causes the wiper fingers to sweep across a resistor card which results in varying ohm resistance readings to be sent to the fuel gauge. The resistor card with get film on it, corrode, smear; or the contacts with break off/get bent, and you will lose the electrical contact between the resistor card and wiper fingers. You can either buy a replacement level sensor assembly to retrofit onto your existing fuel sender assembly, or just buy a whole new one with new pump and everything to drop in. Knowing you have an aftermarket sender assembly, there is no telling what level sensor assembly will retrofit to it...so I would just buy a whole new pump module assembly
Old Feb 21, 2012 | 01:16 PM
mikh338's Avatar
so we had the whole unit out today and when we manually move the float with our hands my gas guage works again. we put it back in tank and it didnt work again so we tapped ontop of the sensors and its working again. we shall see how long that lasts. now when we were looking at the resistor card and the fingers on the tabs it looked like one tab had 3 fingers and the other tab only has 2 fingers it looked like it was either bent down or missing?
Old Feb 21, 2012 | 07:51 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Your sensor is bad... a missing wiper says it all.
Old Feb 21, 2012 | 08:50 PM
mikh338's Avatar
you wouldnt happen to have a part number would you or know the best place to look?
Old Feb 21, 2012 | 10:28 PM
LT1Formula007's Avatar
I'm having the same problem in a 98 trans am. Whats the fix? Sending unit or a whole fuel pump module? Assuming the sensor prongs being broken cause this, is that part available seperately from the module assembly? thank you!
-james
Old Feb 22, 2012 | 07:08 AM
Ollie8974's Avatar
Here you go guys, Racetronix $49.00
http://www.racetronix.biz/items.asp?...Module%20Parts
Old Feb 22, 2012 | 08:52 AM
mikh338's Avatar
awesome, only $49 for the fuel level sender, thats deff worth it to me this guage has been driving me nuts haha. thanks a lot!!
