Injector choice
Old Feb 28, 2008 | 08:16 PM
LS1IMPULSE's Avatar
Default Injector choice
Just trying to see whos running what injectors out their? Big High-Impedance injectors, big low impedance with a driver box? Im looking to make 800WHP but want something that can go above that incase I need it in the future.
Old Feb 28, 2008 | 08:25 PM
Sideways240sx's Avatar
Rc 75's might do the trick for ya, but i dont know what they max out @ but should be good for more then 800. 60's usually max out around 700-800.
Exoticperformance sells the 75's.
Good luck, Chris
Old Feb 28, 2008 | 08:45 PM
Chiet_SS's Avatar
Low impedance 95lbs injectors that way you can still have room to play!
Old Feb 28, 2008 | 08:59 PM
ninetres's Avatar
I got my 96lbers and driver box from the sponsor Nasty Performance. Nate is the man for fuel parts. I made well over 700whp through a TH400 and 9" and the injectors were barely stretchin' their legs. He can set you up with a nice boost referenced FPR too.
Old Feb 28, 2008 | 09:41 PM
SUPERBOOST's Avatar
Racetronix has a new 79 lb high impedance injector out.Not too much info or feedback on them yet though.
Old Feb 28, 2008 | 09:45 PM
ninetres's Avatar
I've generally heard the 60lbers at high pressure do better than the 75lbers at ANY pressure.
Old Feb 28, 2008 | 10:30 PM
LS1IMPULSE's Avatar
yeah i found a set of low impedance 65# SVO injectors but hadnt really seen anyone else with them. I want to keep a good idle quality but im hoping for something that can handle around 1000rwhp.
is there any preference, pros or cons, to switch to low-impedance injectors? or pros/cons to staying with high impedance injectors?
Old Feb 28, 2008 | 10:46 PM
ninetres's Avatar
Driver box set-ups cost more, but can be tuned just as well. Go with the 96lbers and driver box from Nasty. It will cost ya a few hundred bucks more than running 60lbers.........but you know you have enough fuel. You will have enough fuel for 1000+ whp, for down the road
Old Feb 29, 2008 | 01:11 AM
tomz28's Avatar
go big man just did a street tune and we thougth that 42lbs injectors would be good at 65 psi BIG wake up on that damn car push them to 94% IDC and it was only going to be 500 to 550 rwhp set up its more like closer to 600 what was i thinking LOL should have gone to 60s good luck on the injector hunt
Old Mar 3, 2008 | 12:37 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Low-z are generally faster and do not have problems working at higher pressures like high-flow/high-z injectors do:
This setup will make using low-z injectors simple and reliable.
http://www.racetronix.com/RX-ICH.html
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 5, 2008 | 10:59 PM
LS1IMPULSE's Avatar
how long is the cable from the box to the injector harness?
Old Mar 5, 2008 | 11:06 PM
Racetronix's Avatar
LS1TECH Sponsor
All the harness lengths are listed in the ad....
driver box to injector harness connections 40"
Custom lengths are available upon request.
__________________
>WEB SITE<
Old Mar 5, 2008 | 11:16 PM
9secz's Avatar
Big low-z injectors work very well on the street. I ran Delphi 95s driven by the factory LT1 PCM and a VersaFueler on my 9.47@148 Camaro for almost 4 years with no idling or cruising problems. *Very* crisp throttle response and 900 rpm idle in gear all day on race plugs.
The problem with big high impedance injectors is that the opening time varies widely from injector to injector. This ~0.5ms variation is no big deal on the dyno or at the strip where the pulsewidth is much longer than 10 ms, but it can really screw up idle fueling where the average pulsewidth is in the 2ms neighborhood.
Also, please remember that the VersaFueler was granted a United States patent, and the AEM box shown above is infringing on that patent, which is against the law.
Jeff
http://para.noid.org/~lj
Old Mar 5, 2008 | 11:29 PM
Racetronix's Avatar
LS1TECH Sponsor
Jeff
The patent office hands out many patents that are not researched properly.
These types of circuits have been around way before that box came out and will not disappear. A patent is only good if you can afford to back it up with legal action. Then it becomes a matter of who has deeper pockets.
Our harness is available for the A/T box as a special order item. The AEM box offers the best value for the money and is well built. That is why we offer it in our bundle.
__________________
>WEB SITE<
