LS1 or LS2 style PP rails for my setup???
Old Mar 9, 2008 | 08:58 PM
Hugger's Avatar
Default LS1 or LS2 style PP rails for my setup???
I am trying to put LS2 fuel injectors into a FAST intake on my LS1 car. I know that the LS2 injectors are shorter than LS1's and have different connectors. I want to use Professional Products fuel rails. Should I get the LS2 style rails or the LS1 style rails. Common sense tells me to try out the LS2 rails. Anyone ever tried this?
Old Mar 10, 2008 | 03:33 AM
dkrowner's Avatar
you have to use ls2 rails and a kit that fast makes just for this use.in yes thats what i had to do
Old Mar 10, 2008 | 04:21 PM
Hugger's Avatar
I have seen the kit that FAST sells. Since you have used it can you tell me if the little pieces that connect to the injector go on the top or the bottom. It seems like if they went on the bottom of the injector it would make it harder to squirt fuel into the motor.
Old Mar 10, 2008 | 08:21 PM
dkrowner's Avatar
it becouse with the ls2 style injectors the bottom 0-ring is not the same size as a ls1 injector
