Racetronix problem
Old Mar 12, 2008 | 06:58 PM
XtreemeChaos's Avatar
Default Racetronix problem
What's it mean when fuel is shooting out of the top of the pump instead of going out the feed tube in a racetronix setup?
The pump kicks on and sounds like it primes just fine. My car is not getting any fuel to the rails. I then checked to see if fuel is coming out of the tank at all and it wasn't. Then I pulled the pump and instead of the gas being fed into the feed tube, it is spraying out of the hole opposite of the nipple (marked "Opening" on the attached sketch). The pump is a little less than 1 year old and has about 9k miles on it.
Old Mar 14, 2008 | 05:21 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Something has caused the pressure safety bypass valve to stick open.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 14, 2008 | 06:13 AM
Is there anything I can do to find the cause or to fix it myself? Is there a way to reset the valve and see if it happens again? That picture looks like it's internal.
Old Mar 15, 2008 | 04:19 AM
Racetronix's Avatar
LS1TECH Sponsor
Unfortunately there is no set procedure we can recommend to fix this problem. Once something is lodged under the valve seat it is tough to clear.
Please e-mail support@racetronix.com with your problem and all your contact info.
__________________
>WEB SITE<
