fittings question
Old Mar 19, 2008 | 09:58 AM
SSilverSSurfer's Avatar
Default fittings question
i put teflon on my fittings and proceeded to put them on my edelbrock rails. now heres the catch, it threads in fine by and and then it gets tight. i turn it somemore and there are still threads showing will this be ok? some setups ive seen are like this and others bottom out. any insight? thanks
Old Mar 19, 2008 | 10:05 AM
01WS6/tamu's Avatar
As long as you have teflon on it either tape or liquid sealer and it is physically tight than you will be fine. It is a pipe thread fitting and is actually tapered. I've seen a few that are bottomed and others with threads. For the most part it is how deep they are tapped when they are machined that makes the difference. Don't sweat it.
Old Mar 19, 2008 | 10:10 AM
thanks chris, thats exactly what i was looking for
Old Mar 19, 2008 | 10:32 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Ya, I had threads still showing on my rail fittings. No big deal. They don't leak or anything.
Old Mar 19, 2008 | 10:40 AM
ss1's Avatar
ss1
Just another thing to add here. The rails where you see the fittings bottomed out are a straight -AN o-ring type thread.
Old Mar 19, 2008 | 11:34 AM
thanks guys and i did use the liquid teflon. i appreciate the help
