Homemade Premium?
Old Mar 20, 2008 | 11:20 AM
seawolf18's Avatar
Default Homemade Premium?
In my area the highest octane gas you can buy is 91. I have a high compression heads/cam car and need higher octane fuel (92, 93). A couple of local guys were saying they make their own premium gas by mixing e85 with regular 87 octane gas to make around 93 octane gas. They say it works in their cars really well, they didn't need to modify anything, and its cheaper. I was wondering if anyone has done this before with a LS1 and what they are saying is true? Also, if it is feasible what ratio of e85 to regular would I have to mix for it to work?
Old Mar 24, 2008 | 10:53 PM
TheBlurLS1's Avatar
That's what she said...
You can figure up the e85 at around 100octane (from what I hear).
[(X gallons of e85) * 100 + (Y gallons of 91) * 91] / (X + Y) = Overall Octane...
But............
You get less heating value from e85, meaning you need to run it richer. e85 needs to be run at 9.76:1 AFR. You'll have to figure up a new air/fuel ratio to run each time, or use the same mixture each time.
[(X gallons of e85) * 9.76 + (Y gallons of gasoline) * 14.7] / (X + Y) = Ratio for e85 + gasoline.
Old Mar 25, 2008 | 11:20 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
You could also try the old toulene / xylene mixture.
Old Mar 28, 2008 | 10:37 PM
vaticano's Avatar
I would think, if you have the MAF enabled and fuel trims working off the your narrow band o2's that you could mix 25-30 E-85 with out issue. Iv'e heard the E-85 is 105 octane.
Old Mar 28, 2008 | 10:42 PM
jsteele90's Avatar
yeah ive never tried the toluene but ive heard it works wonders.
