Do i need to up grade fuel rails?
Old Mar 29, 2008 | 04:55 PM
nastysupaspt's Avatar
Default Do i need to up grade fuel rails?
Ok guys here is my set up i'm running heads and cam stock bottom end with a APS F Body twin set up going to run 7lbs of boost possibly 10lbs pending what it does on 7lbs. now i'm gonna to go with twin 255 intank pumps and 76lb injectors. what else do i need and do i need to up grade the stock fuel rails i here guys telling me stock LS1 rails are good for up too 700hp is that true? i need some help here
Old Mar 29, 2008 | 05:07 PM
BOTTLEFEDLS1Z's Avatar
Might as well make the car a return style set-up and never have to worry about it again.
I'd think that you will need bigger rails with the twin pumps, but I'm no expert
Old Mar 29, 2008 | 05:13 PM
I was going to just do the rails and get it over with but my buddy was saying that he has seen C5 vettes with 600-700hp on stock fuel rails now whats the difference between our fuel rails and C5 rails i would of thought nothing.
Old Mar 29, 2008 | 07:04 PM
I believe the regulator is on the rails for a vette vs ours being at the back by the tank
Old Mar 30, 2008 | 02:15 PM
other than that there different in size ?
Old Mar 30, 2008 | 06:33 PM
Tiger2o69's Avatar
return style system with a regulator up front is your main thing. Our fuel rails can support 600 i know.
Old Mar 31, 2008 | 02:06 PM
Sweet so the injectors, twin 255 pumps and a fuel pressure regulator up front and i should be good?
Old Apr 2, 2008 | 02:11 AM
Tiger2o69's Avatar
that should handle what your doing.
