Does it matter where the Regulater goes?
How do you plumb your fuel?
I was thinking connecting the front and rear fuel rails with a T. Have the fuel go in the rear at the T and exit the front T where the 1:1 regulater is.
Good Bad???
Good Bad???
that is essentially how I did mine. I instead used a Y fitting (not a T fitting) and supply the fuel to the back of the rails. Front of the rails then go into 2 separate ports of the regulator (my regulator acts as the second "T" in your case)
on my car i go in one rail, cross over to the other rail at the front, come out the back of the other rail go through the regulator and out
the fittings and lines around the rails are expensive enough without me buying double
So, the fuel comes in the driver's side rail, runs through that rail, crosses over to the passenger side rail, then out to the regulator and back to the tank. Pressure is regulated after both rails.
