SVO 30# Injectors
Old Mar 29, 2008 | 09:43 PM
97MysticZ's Avatar
What's a Sticky?
Default SVO 30# Injectors
Okay, well I bought a set of SVO 30# red tops. I want to go ahead and replace the o-rings on them- should I just go to the part store and give them the p/n on the injector? Obviously, they are used, should I worry about cleaning them or anything before I install them? I want to make sure they are performing in top shape.
Old Mar 30, 2008 | 04:16 PM
Mike @ New Era's Avatar
If you want to make sure everything is good , you can send them to us and we will ultrasonic clean them , and replace the orings , pintle caps , and top filters and flow test them for you as well , and you will receive a flow data sheet with each injector individually labelled . You can order the service here if you are interested www.neweraperformanceparts.com .
