Converting to single fuel line
Old Apr 1, 2008 | 10:29 AM
JVetthead's Avatar
Default Converting to single fuel line
Doing a 427 swap with LS7 top end in a '98 C5. Need to know how to con vert from double to single fuel line or if the stock pump will even support 550-575 rwhp. What would a good setup be for a dedicated road race car?
Thanks
Old Apr 1, 2008 | 11:37 AM
Nasty N8's Avatar
Give me a call I think I can help you out.
Nate
Old Apr 3, 2008 | 02:47 PM
JVetthead's Avatar
Nate
Thanks, I'll give you a call when I get closer to that end of the project..
Joe
Old Apr 3, 2008 | 04:39 PM
Z06PSI's Avatar
May I ask why you would do that? Seems counter productive for a high H.P. setup.
Old Apr 6, 2008 | 03:37 PM
JVetthead's Avatar
Well thats why I am here asking questions... My current set up has the stock '98 return line. I am building a 427 with LS7 intake which I presume has a returnless fuel rail.. I need to know the best (for me) setup to make this work.
Old Apr 6, 2008 | 03:41 PM
405HP_Z06's Avatar
You don't need to convert to the 'returnless' system to support the use of the LS7 intake. Use the LS7 intake with aftermarket fuel rails, i.e. FAST or Aeromotive, and upgrade your in tank fuel pump. This is least costly and most effective solution for this situation.
Old Apr 8, 2008 | 04:36 PM
JVetthead's Avatar
Hey thanks... Finally a positive response
