Easy Way To..
Old 04-21-2008, 09:12 PM
94m6Z28's Avatar
Default Easy Way To..
is there a easy way to drain the tank that will minimize fuel spill-ege? i was wondering if there is any one to trick the fuel pump and use it drain the tank??
Old 04-21-2008, 10:34 PM
ZL1Killa's Avatar
yeh but you will need to take it out of its housing and stick it towards the bottom of the tank, as the way it sits you won't get the last 2 gallons or so of gas from the bottom of the tank.
get you a 12V battery, get your some alligator clips (wires with clips on the ends) and connect to the battery + and - and hear her run!!! just DO NOT RUN IT DRY... you will burn up your fuel pump, also be careful about cavitation i believe it is where you are sucking fuel and it creates a air pocket because you are moving the fuel faster than it can get out of the tank
Old 04-21-2008, 11:20 PM
BigBlockCamaro's Avatar
that what my idea was.. 12v battery and a bucket.. haha
Old 04-22-2008, 02:10 PM
94m6Z28's Avatar
ok, but where do i connect the alies to?,
as long as i get enought out to make it easy to move. i got a full tank befor it decided to die on me. soo as long as i can get 90% of it out and sae it ill be happy.
Old 04-23-2008, 10:21 AM
ZL1Killa's Avatar
what died on you? if the pumps dead, then how r you going to get it to run. if you have everything where it was on the car, simply disconnect the fuel line right in front of the filter and run your two wires to your pump...id have to find the wiring diagram....srry
