Fuel level sender question
Old Apr 23, 2008 | 09:55 AM
HAMRHEAD's Avatar
Default Fuel level sender question
What is the easiest way to tell if it is the fuel level sending unit or the fuel level gauge that isn't working? I have the pump pulled so everything is accessible. How can I test the sender to tell if it is actually working?
Old Apr 23, 2008 | 10:12 AM
Nasty N8's Avatar
It is a variable resistor so check the ohms from empty to full. Fbody should be 40-250ohms
Nate
Old Apr 23, 2008 | 11:49 PM
HAMRHEAD's Avatar
What wire should I test?
Old Apr 29, 2008 | 10:47 PM
HAMRHEAD's Avatar
Got it but gauge still isn't working right.
https://ls1tech.com/forums/showthrea...04#post9266104
