Plastic Tank With Braided Line
Thanks
Brad
If you use the Aeromotive fittings, you'll also need an Aeromotive -8ORB to -8AN fitting so you can connect it to a standard -8AN braided hose.
Aeromotive also makes the SAE J2044 fittings in 5/16" (which is the size of the EVAP line if you use that as a return), and those take -6AN fittings.
Thanks
Brad
