Wiring a dual in tank system in a cell?
Fuel cell, not the stock tank. I am going to be running dual Walbro's 340.
How should I wire them? Wire one pump via the normal harness connections and the other through a relayed ignition-on switch? Or is it safe to draw two Walbro's off the stock harness directly? Let's see, I guess that would be about 9 amps each.
Jeff
Jeff
The stock wiring can not support 1 340 fully. Run new feeds and grounds for both pumps you will need to relay each pump as well. Use the stock wiring to trigger them.
Nate
Nate
Dang your good. I never thought of that.
On another thread I noticed it's not good to run both pumps at the same time. Apparantly it heats up the fuel which I don't need additional troubles with.
How to wire a Hobb? I am thinking one pump off the standard harness and the other relayed via a Hobb switch. I got to go find out more about those things.
Jeff
Jeff
