Vic Jr
Old May 8, 2008 | 10:24 AM
dhdenney's Avatar
Default Vic Jr
Already have a set of LS1 fuel rails. Yes I know easy way is to get Vic Jr package with rails. But I've got a set of rails. Modding is no problem, is it an easy mod or not worth it?
Old May 8, 2008 | 11:42 AM
Nasty N8's Avatar
Not worth it the Vic without rails has no injector holes. You would need to have the intake machined for the injectors. Just get the intake with the rails and sell your rails.
Nate
Old May 8, 2008 | 04:31 PM
ryarbrough's Avatar
I've got a fuel injection style victor jr that the previous owner had modified to accept a standard rail... The Edelbrock rail mounts are crap in my opinion, and if he hadn't had this done, I'd have stuck with a fast 90/90 setup... I can post pics of the modifications if needed... I don't think, however, that it'd be a backyard project.... I know he took it to a machine shop so that it could be done properly and assure that the rails were at the proper height, witdth, angle, etc.
Old May 8, 2008 | 09:35 PM
theblur98ss's Avatar
I was in the same boat at you. I sold my rails and got the vic jr with rails.
Old May 8, 2008 | 10:36 PM
dhdenney's Avatar
I was under the impression you could get buy the FI Vic without the rails, hence my Q.
Old May 12, 2008 | 02:28 PM
stevieturbo's Avatar
You can buy an EFI Victor Junior without fuel rails, but with injector holes.. EDL-29085
Thats what I sent to you N8.
You can buy it carb only, efi/no rails, efi with rails.
Old May 12, 2008 | 03:50 PM
platinum1's Avatar
its not hard to mod.i modded the super vic for my application
Old Apr 9, 2010 | 07:51 PM
bww3588's Avatar
does anyone know the demensions of the injector holes? i have a good deal lined up on a carb intake and have access to a mill to make the holes, i just need to know what size and everything to mill the holes.
Old Apr 10, 2010 | 09:19 PM
Duffster's Avatar
If you're running LS2/LS3/LS7, you want 14mm holes... if LS1/LS6, 15mm holes.
I'm running an LS2/3/7 GMPP intake with my LS6 engine and changed to 14mm o-rings for the injectors.
