fuel pressure problem
Old May 12, 2008 | 11:39 PM
chevyforlife's Avatar
Default fuel pressure problem
on my 2000 z28 camaro the fuel pressure goes up and down and will stay at like 15 pounds but if i play with gas pedal it will go back up to 55 and then eventually drop back down i have replaced pump like 250 miles ago with a wallbro 255 so if anyone thinks they know whats goin on it would help thanx
Old May 13, 2008 | 05:28 AM
RedsrtAk's Avatar
bump for this guy...I see you found the forums..
Old May 13, 2008 | 07:09 AM
jmill96Z's Avatar
Sounds like it could be a regulator. When you turn the key to acc will it hold pressure?
Old May 13, 2008 | 11:51 AM
yeah it holds pressure its been doin it ever since i got the car i dont know if when i put the new pump in if it even fixed it but it definitly quit doin it for a while
Old May 13, 2008 | 06:42 PM
jmill96Z's Avatar
Did you replace the filter also?
Old May 14, 2008 | 12:55 AM
yeah sure did
Old May 14, 2008 | 02:29 AM
35th SS's Avatar
might have a bad connection on the wires.behind underneath the backseat.
