Need fuel injector info---
Old May 15, 2008 | 08:00 PM
MYHAWKROCKS's Avatar
Default Need fuel injector info---
Well i've been looking around for some injectors and I had some questions. Whats up with high impedance injectors? Are there low impedance injectors? Are there injectors that I would need adapters or splice into the harness? any info would be nice, Thanks
Old May 17, 2008 | 11:48 AM
anyone?
Old May 18, 2008 | 03:00 AM
stevieturbo's Avatar
What exactly do you mean, whats up with them ?
Yes there are. Why do you ask ?
Injectors inject fuel. You do not need adaptors, and you do no splicing.
Now.....if you could ask a more specific question relating to your problem, or needs, then a better answer will soon follow.
Although virtually every topic will have been covered, if you search a little.
Old May 18, 2008 | 06:26 PM
OK, how about this...
What are the differences between high and low impedance injectors?
Would I need a wiring harness adapter for different injectors or can I just plug in Accel, FAST, SVO, Racetronic, Siemens with no problem?
Again any info would help, Thanks
Old May 19, 2008 | 11:20 AM
The opening/closing strategies are different, which ends up with the lowZ requiring more current to operate. But because of this, they can work better, which is why the big injectors tend to be lowZ.
You cannot fire LowZ injectors directly from the stock PCM.
Until you need lots of fuel you dont even need to consider low impedance injectors though. If heading north of 850-900rwhp, then yes, it is something to consider
If you buy a suitable injector, then they plug straight in. They just use the typical Bosch style Mini Timer plug.
