What Would You Use????
Old May 18, 2008 | 07:59 PM
inahrtbt's Avatar
Default What Would You Use????
Hey guys would like your opion..
What intank pump would you say would be great "as a direct bolt in" for a STS rear mount turbo with 625 rwhp in a 1998 LS1 F-Body? Has All factory fuel system now except 60LB injectors. The car is running 11LBs of boost. Thanks..
Old May 18, 2008 | 08:37 PM
slow's Avatar
racetronix, and a boost a pump
Old May 20, 2008 | 08:01 AM
ZL1Killa's Avatar
grab you a racetronix PnP kit
Old May 20, 2008 | 10:16 AM
Nasty N8's Avatar
Racetronix kit will never support that much turbo power with factory lines and regulator without being on the ragged edge. You are in need of a dual pump setup with our Lonnie's/Racetronix dual pump kit one pump will run all the time and the second will kick in under boost via a Hobbs switch. Give me a call for some details and options.
Nate
Old May 20, 2008 | 02:53 PM
ZL1Killa's Avatar
Nate
he is right. Nates got all you need
