wot pinging
Old Aug 10, 2003 | 12:33 PM
00 Z-28's Avatar
Default wot pinging
At wot I have pinging(det)and black smoke out of the exhaust. Help!!!! I have run 93 oct. Exxon gas since the car was new.
Old Aug 10, 2003 | 03:14 PM
CAT3's Avatar
Restricted User
Default Re: wot pinging
Try an octane booster, reduce timing check plugs. If they are stock plugs pull them out and throw in a set of NGK TR-6 plugs gapped at .038. The stockers are POS.
Old Aug 11, 2003 | 03:46 AM
soundengineer's Avatar
why .038??? why not .055??? I thought .38 was for nitrous...wouldnt that burn really hot for a stock motor???
Old Aug 11, 2003 | 04:19 AM
silverTA's Avatar
GO WITH njk tr55 AT .55 AND CLEAN THE FUEL SYSTEM
Old Aug 11, 2003 | 07:27 AM
00 Z-28's Avatar
Thnks for the feedback!!!
Old Aug 11, 2003 | 07:36 AM
4thGENRETARD's Avatar
TR6 are for nitrous, ditto on .038.
NGK's TR55 are good. with your mods .55 is also good. I run DENSO IRIDIUMS at .55.
Check your A/F ratio. Tune it properly.
As for black smoke, if it persists after tune, READ your old plugs, if one or more show oil deposits, check compression on that cylinder/s.
Post your findings for further help.
Old Aug 11, 2003 | 05:14 PM
00 Z-28's Avatar
Thanks for the feedback!
Old Aug 11, 2003 | 07:05 PM
CAT3's Avatar
Restricted User
My bad, was thinking of N2O app's. I use the TR6 at .035". Sorry.
Old Aug 12, 2003 | 12:00 AM
CAT3's Avatar
Restricted User
Ok, retraction in effect, he lives in Tx, its hot there right? Good try the TR6 gapped at .038 or so, maybe a little more but not more than .040". TR6 are a colder step plug therefore keeping the flame back enough to help compensate for higher intake charge temps. Dont ask why, I am dont have a Doctorate, but they work ok. NataSS had some issues laterly in the hot weather. I use TR6 cause i do spray and race....A LOT. But never hurt me NA wise, I might give up an irish pubic hair but thats worth it to me and not have detonation problems. Ditto on the tuning suggestions.
Old Aug 23, 2003 | 10:36 PM
00 Z-28's Avatar
OK!!!! I check the comp. >>>> it's OK. Replaced the Denso plugs (dry but w/ a little carbon) that came w/ the car with the NGK TR55 >>> gapped @ 55, that took care of the problem. My best freind today was a 1/4 inch extension.
Thanks Guy's
