What injectors for my set up
Old May 27, 2008 | 11:56 AM
tasilver's Avatar
Default What injectors for my set up
I have heard from a few people and members on this board that my injectors will be maxed out. I have a TR224 112lsa cam, CNC & angle valve job LS6 heads, ferra valves being installed. Along with an undrive pulley and port & polished throttle body. I am taking my car to get dyno tuned after the install. (STILL WAITING ON THE HEADS VALVE JOB TO BE DONE )
So what injectors would do the trick. My TA is a M6 with a strange 12 bolt 411 gears, LS7 clutch, and full suspension (UMI LCA, SFC,.....).
Any one think I can run in the 11's?
Thanks for any info.
Old May 27, 2008 | 03:16 PM
Evans752's Avatar
Your injectors may be maxed out but I dont know for sure but I would try to get a set of 2001-2002 injectors or a set of 30lbs and have someone tune them for your car. You should be in the high 11's and maybe the mid 11's on a set of tires (drag radials, et streets, et drags ect) and a track that will let you hook and 60 foot and drive it like you stoled it LOL. Good Luck and have a good time
Old May 27, 2008 | 09:18 PM
Mike @ New Era's Avatar
Get some 30 lb injectors , you will be fine with those . We have the new and improved style in stock for $269.95 , you can order them here www.neweraperformanceparts.com .
Old May 27, 2008 | 10:22 PM
b005td's Avatar
Originally Posted by Mike @ New Era
We have the new and improved .
whats improved ?
Old May 28, 2008 | 09:03 AM
ZL1Killa's Avatar
you can get 30#ers 32#ers 36.5#ers 42lb ers... if you got more plans the 42#ers would work fine for you and would support up to around 500hp
Old May 28, 2008 | 12:11 PM
tasilver's Avatar
Thanks for the info guys.
Will the ford injectors just plug right into my fuel rails and intake? or is there some modding needed?
Old May 29, 2008 | 02:59 PM
The new 30lb injectors are lighter , and are plastic bodies . This makes them a faster more accurate injector that doesn't run as hot .
Old May 29, 2008 | 03:20 PM
YellowToy/A's Avatar
get 42 pounders. Dont put them in until you can tune them
