New Fuel Pump - Trouble Starting
I had the pump installed when my new rear went in, but now I think I'm gonna have to cut a hole in the floor anyway to fix whatever problem it is.
Try installing a pressure gauge on the rail & see how long the pressure holds after you shut the car off.
It could be due to a line in the tank leaking. Most likely the one that connects to the inside top of the sender.
