Will this bypass regulator work with my carb'd LS1
http://store.summitracing.com/partde...5&autoview=sku
I've converted over to carb/MSD 6010 on my '98 LS1. WIth the OEM pump, will this regulator work. From my research it should, I just want a second opinion before I order. It has the same features as the Aeromotive regulator but this Holley is less than half that price.
I appreciate the help!!
I read in June 2008 issue of Hot Rod last Pit Stop section about a 95 Mustang owner converting his car to carb. It has a diagram showing how to route the fuel lines using the original OEM pump. They also used a Kinsler bypass valve in the return line. It also used the regulator you posted.
