Return Line & fuel pump.
Old Jun 2, 2008 | 11:35 AM
oneslowbowtie's Avatar
Default Return Line & fuel pump.
Hello, I am doing a LS1 swap into a 72 Chevelle. I have a -8 line for the feed fuel line from my original SB carb set up. My question is what size line will I need for a return? Also what external fuel pump & pressure regulator is everyone running. This will a be a fuel injection application. Thanks in advanced.
Old Jun 2, 2008 | 03:34 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
-6 should be good for the return if you are doing a return type setup...
Old Jun 4, 2008 | 10:27 AM
Thanks
Old Jun 4, 2008 | 06:55 PM
Nasty N8's Avatar
What is your setup and HP goals? Give me a call I have complete kits for LS swaps.
Nate
