30lb SVO injectors enough for a 422
I currently have 36lb svo's but they're too wide and are hitting my direct port nozzles. I'm guessing the 30's would be skinnier and should clear. I've heard that 30's are all the MTI uses on their big motors. Is this the case?
Re: 30lb SVO injectors enough for a 422
I cant imagine running a small injector like that on your engine. I am not a expert, hell I am tryign to get info for mine as well, but I used the fwhp x .45 (Non turbo.SC) and then divide by 8 and see I need about 30#, so I picked up a set of Accels from a friend for free. They flow 34# in our car, so the SVO's should as well. Wonderful having higher Fuel Pressure.
