Versafueler New low price
We can now offer a new lower pricing on the exceptional VersaFueler.
VersaFuelerTM DETAILS
The Acceleronics VersaFuelerTM (US Patent 6836721) simply splices in between your current ECU and the big honkin' injectors that your monster motor needs. Splice it in, hook it up to switched 12-volts and ground, and you're on your way to the races.
The VersaFuelerTM provides separate "peak and hold" logic circuits for each injector. The "peak" supplies up to 4 amps to snap big injectors open quickly, something your ECU cannot do. Once the injector is open, the "hold" turns down the current to prevent the injector from overheating.
Your ECU will never know that it's running the Acceleronics VersaFuelerTM instead of the injectors. The VersaFuelerTM will not cause your engine control computer to "throw a code", or turn on the check engine light, or do anything else that would be annoying.
The VersaFueler TM comes with everything you need for installation. The locking connectors are dustproof and waterproof. Inside the anodized aluminum enclosure, all circuits are encapsulated to make them resistant to moisture, dust and vibration. The Acceleronics VersaFueler TM is designed to provide years of trouble-free service.
THE BOTTOM LINE a must for cars over 800rwhp
At $319, the Acceleronics VersaFueler is the best way to run low-impedance injectors on your factory EFI engine.
Also VersaFueler and 96# inj. $799.99
Nate
Nate
