Fuel Problem Need Help Asap
Old Jun 6, 2008 | 10:20 PM
camaro_ss_97's Avatar
Default Fuel Problem Need Help Asap
Ok Was Gonna Start My Car For The First Time I Ran Nasty Performance Fuel Line From Filter To Rails. With Quick Disconnect Fitting At Rail. When I Try To Start Car Does Not Run Turns Over But Thats It. And Fuel Spills Out The Quick Disconnect Fitting At Rail. It Is Not Getting Fuel I Tried Spraying A Bit Of Starting Fluid And Fired Right Up And Then Died. So Any Reason Why Disconnect Is Leaking?? Please Any Help Would Be Great...
Old Jun 7, 2008 | 01:41 PM
anyone??
Old Jun 7, 2008 | 01:48 PM
jmdale1984's Avatar
It probably isn't on all the way
Old Jun 7, 2008 | 02:46 PM
well i thought that 2 and took it off 3 times and re-connected it same thing happens. i think the quick connect is bad?
Old Jun 7, 2008 | 03:53 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Verify it is the correct size. Look at the part number / description on the package & measure the tube connection. Also look at the o-ring inside the quick connect & see if you nicked it.
Old Jun 7, 2008 | 05:35 PM
ok i got the fuel leak fixed now car wont start acts like it wants to but it's not. i have a stock tune in the computer i have do you think that big cam is not letting car start and idle?
Old Jun 7, 2008 | 05:53 PM
jmdale1984's Avatar
It's probably trying to do idle learn... might have to give it a bit of gas to keep it running for the first 30 seconds or so
Old Jun 7, 2008 | 06:48 PM
well i tried to start it again and it won't idle without spraying starting fluid in the tb
Old Jun 8, 2008 | 01:09 PM
he just thought of something would the vats system have anything to do it not wanting to run??
Old Jun 8, 2008 | 01:16 PM
jmdale1984's Avatar
YES! You'll have to have it tuned out of the PCM, or bypass it.
Old Jun 8, 2008 | 01:17 PM
i'm gonna send pcm out to brian at pcmforless what else would you recommend tunning out? if anything?
Old Jun 8, 2008 | 01:22 PM
jmdale1984's Avatar
Get rid of EGR and AIR (unless you really want them, and want to make the effort to keep them in your swap). Skip shift if it's an M6. Might wanna throw out all the EVAP stuff while you're at it. We had to do that on my buddy's 95 Z w/LS1.
That's all I can think of right now... but it seems like I'm forgetting something.
Old Jun 8, 2008 | 01:28 PM
yea arg and air are gone and i have evap hooked up thought it was needed i have it hooked into the intake. if i were to take it out what would , would i just take to whole tube out back to tank or what? and are you talking bout 95greenz28?
Old Jun 8, 2008 | 01:53 PM
jmdale1984's Avatar
Nah... talking about another board member, but he's not very active (Blackesteyes8696). I can't remember exactly what we ended up doing with his EVAP system, I know it's hooked up, but I'm sure it'll end up needing tuned out. He hasn't gotten it tuned yet, so I'm not 100% sure. We used 98 fuel lines on his 95 tank... so we probably did it a bit differently.
