How to tell if the injectors I bought are 28/26
Old 06-08-2008, 04:18 PM
TCW
TCW's Avatar
Default How to tell if the injectors I bought are 28/26
I bought some 28lb injectors and was wondering if their is a PN I can check to make sure they aren't the 26's I am replacing.
Thanks
Old 06-08-2008, 04:55 PM
87MONTECARLOLSXON6'S's Avatar
What part numbers do you have on the sides of the 28lbs injectors you have? Tell us some numbers, or see if they are the same numbers as your 26lbs. I will look at my old 26lbs. and tell you the numbers in a second. This guy on here named Badmire sold me some so called 28lbs injectors until I checked the numbers on the sides of them after they arrived with my Ls1 performance book and they were 26lbs.
Old 06-08-2008, 05:01 PM
TCW
TCW's Avatar
One side-0 280 155 931
Other Side-12561462
Old 06-08-2008, 05:13 PM
Delphi / Bosch
28 lb / hr Injector
Part Number 12561462 (Bosch # 0 280 155 931) - This is a LS1 factory GM injector.
Static Flow Rate: 28 lb/hr (294cc) @ 43.5PSI (300kPa)
Fan spray pattern for superior atomization.
High pressure capability
High Impedance / High-Z
Old 06-08-2008, 05:34 PM
TCW
TCW's Avatar
Anyway of knowing if its the 28.2('98) or 28.8('01-'02)?
Eitherway thanks!
Old 06-08-2008, 05:49 PM
GMP-12554271 - 97-98 = 28.2lbs/ ls1
GMP-12561462 - 01-04 = 28.8lbs/ ls6/ 2001-2002 ls1
GMP-12482704 - 01-04 = 28.8lbs/ ls6/
Old 06-08-2008, 06:00 PM
TCW
TCW's Avatar
I need one of those books you got there
Thanks
Old 06-08-2008, 06:25 PM
Got it from ebay about 2 years ago, How to build a high performance Ls1/Ls6. I think there is a newer one out on there by now... YW!!
