If I get bigger injectors do I have to change computer stuff
So I keep reading about getting bigger injectors. I dont think I need them now...but down the road I am thinking about Supercharging....and I will need them then....so when I get them and put them on...do I have to do some custom programming to make them work or will they work on their own???? This is an issue I do not know anything about.
somebody please explain what I need to do when I buy bigger injectors.
Re: If I get bigger injectors do I have to change computer stuff
will I be able to put them in and drive it to the dyno tuner( being real light footed...putt...putt..putt...putt)??? or will I have to drive to the dyno tuner and put them in on location???
Restricted User
Depends on how much bigger I believe. If you go from your 26# stockers to 88# you'd be better served installing there. 30# should run good enough, but how far is the tuner from your place?
Restricted User
Might try pagin NoGo or TeamZR1 on this as they seem to have a good handle on the whole tuning and injectors...different views as many of us do, but they are both very helpful and dayum smart on it.
well, i know that swapping from 26#'s to 42#'s the car hardly sputters to run. it takes 10 minutes to swap them out, so i'd suggest just doing the swap at the tuners shop. it'd be a ton easier.
