do i need new spark plugs?
Old Jun 11, 2008 | 01:36 AM
LT1Formula26's Avatar
Default do i need new spark plugs?
ok so i just got a new fuel pump from nasty performance...its a waldpro and when i got it installed the car started on the first turn. but i drove it about 5 hrs to madison wisconsin because im living there for the summer and now sometimes it starts on the first turn of the key, but most of the time i have to press the gas pedal a couple times while im turning the key. also, i feel like i have lost some horsepower and my exhaust smells like gas pretty bad.... my exhaust tips get charcoal-colored a lot too. i had an arching plug but i fixed it and now it isn't arching, but im still having this gas smell from the exhaust and starting problem. also, sometimes after sitting for a while, when i get it started, it will sputter sporadically like once every 2 weeks. wierd. the car is a 94 TA. any opinions?
Old Jun 11, 2008 | 05:48 PM
Dex's Avatar
Dex
Sounds like its running way rich check fuel pressure first regulator might have took a crap.
Old Jun 12, 2008 | 01:51 AM
how much would a regulator run me? and where is it located? i don't need a new fuel pump though right? cause that would be a bitch.
Old Jun 12, 2008 | 02:02 PM
bump to the top
Old Jun 12, 2008 | 03:48 PM
koolaid_kid's Avatar
It's at the rear of the fuel rail, at the back of the intake manifold. The first thing to do is to check the pressure. Should be around 38-39 psi at idle, about 43 psi with the vacuum line disconnected. There is a schraeder valve that you can connect a gauge to for verifying the pressure.
Old Jun 14, 2008 | 12:46 AM
ok im bout to get it checked tomorrow. today i went to start it and it didn't even turn over, it just clicked like 5 times and on the 6th it started. really wierd...that doesn't sound much like a regulator does it? well anyways, ill get it checked tomorrow, it think im getting new spark plugs put in too.
Old Jun 14, 2008 | 12:44 PM
exhaust still smells pretty bad.
Old Jun 15, 2008 | 12:10 AM
anyone?
Old Jun 15, 2008 | 02:01 PM
Dex's Avatar
Dex
so have you checked the regulator yet??????????
Old Jun 16, 2008 | 02:16 PM
not yet, im living in a small town right outside madison wisconsin this summer and the shops here are retarded.
