Fuel Pressure Gauge?
Would this work?
http://www.nitrousoutlet.com/catalog...product_id=249
how do you remove the schrader valve? and when you remove it, will fuel start spraying everywhere?
That gauge thats pictured looks like a mechanical gauge. Im guessing that that goes right on the end of the rail. If you wanted one that you can view from inside the car, you would be better off getting an electrical gauge.
I have an autometer "inside the car" cobalt series guage for my fuel pressure...
I got one of these fittings for the sender... just haven't figured out what all I need to do to install it yet...
also... the little black plastic cap that unscrews off of the FR... when I put this new sender adapter on there, do I need a new special cap to screw onto the end of it? Or will the black plastic one suffice just screwing it onto the end of the new adapter?
I dont know if that one has a shrader valve in the end of that adapter, or if you can put one in it. If it does have a shrader valve, you dont NEED the cap, its just protection. Usually your stock cap should fit it. If it doesnt have a shrader valve, youll need something a little stronger than the plastic cap to make sure the fuel doesnt leak out. Btw dont forget to use thread sealer on all your connections.
The fitting pictured above would work (use the female pipe thread in the middle for the sender) but you'll need to cap off the male AN port with a cap that's available for AN ports. Use threadsealer on the pipe thread, not on the AN ports.
