Trap Door Dimensions?
Old Jun 29, 2008 | 12:15 PM
transam69230's Avatar
Default Trap Door Dimensions?
What i am looking for are some numbers on where to cut the hole for the trap door for the fuel pump access hole. I have already done a search and all i can come up with are pics, I don't want to make a cut not knowing any numbers cause i just don't want to screw anything up. Any help is appreciated!
Old Jun 29, 2008 | 12:53 PM
Carter01's Avatar
Fuel Pump: Drop tank or make access door?
Just scroll down the fuel & injection homepage and look at his post. The answer you are looking for is in that post.
Good Luck
Old Jun 29, 2008 | 01:22 PM
I still didn't see where the exact measurements were to cut. I just saw more writeups with more pictures, no numbers.
Old Jun 29, 2008 | 01:36 PM
Travis99LS1's Avatar
http://www.gonicd.com/intankinstall/...mpinstall.html
man this is what i used when i installed my racetronix..if you want the exact measurements i could measure it for you..but if you look at the pictures you can see where you need to cut
Old Jun 29, 2008 | 01:40 PM
Its not for me, my buddy is going to cut the door for me cause i don't have any tools. He has a hard time using computer because it past his time. If you could meausure for me that would awesome.
Old Jul 1, 2008 | 08:40 AM
2000Firehawk's Avatar
use a dremel w/cut-off disc too...
as hoses are right up againest the metal you will be cutting...
