regulator how to
Old Aug 21, 2003 | 08:16 PM
RICE ETR's Avatar
Turbo Addict
Default regulator how to
I have done a search... but can't seem to find a straight answer.
I am going with either an aeromotive or CAS regulator....1:1.. and was planning on splicing into the return line after it leaves the block under the driver side seat. Can anyone tell me what fitting i need to screw into the block or what kind of hard fuel line adaptors i will need to make this work?
Thanks
Old Aug 22, 2003 | 06:03 AM
smokinHawk's Avatar
Default Re: regulator how to
i know the fitting of the Tee return block is a 3/8 flare end type thread.
Old Aug 25, 2003 | 12:53 AM
RICE ETR's Avatar
Turbo Addict
sorry for the delay in responding...Thanks for the help SmokinHawk!
Old Aug 26, 2003 | 06:08 PM
Chris99WS6PWTMET's Avatar
Best way is to just get rid of the T-block. Cut and flare the main feed lines on both sides of the block. Use a -6 sleeve and tube nut on both sides and install a -6 union. As for the return line cut the hard line and install a -5 sleeve and flare nut then get a -5 to ?? (whatever size line you are using) union and connect. Remove in tank regulator and you're good to go.
Old Aug 26, 2003 | 06:09 PM
Sorry.. I just re-read your post and now realize that you are installing the CAS regulator in back. Belay my last (nevermind).
The above post works great for ridding the T-block when installing an upfront regulator.
