CAS Sumped tank
Old Aug 23, 2003 | 02:42 AM
SuperSport2000's Avatar
Default CAS Sumped tank
Anyone ran this tank? If so how is the fit and finish?
Old Aug 23, 2003 | 10:38 PM
Slow Z28's Avatar
Default Re: CAS Sumped tank
PSJ had it put in his car, don't know anything more than that. I will be getting one in the near future hopefully.
Chris
Old Aug 25, 2003 | 12:15 PM
highgmc's Avatar
I have one, you can get them from speed>>>
very nice fit, works great
Old Aug 25, 2003 | 04:17 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have one.
Had to go with a 99-02 filler neck and gas cap.
Old Aug 25, 2003 | 08:15 PM
how about the fuel level guage being off? If you fill up you tank doesn't it leak out the breather?
Old Aug 26, 2003 | 09:39 AM
LS1Tech Co-Founder
I have not put gas in it yet. Znines had to cut down the fuel level sender, I'll ask him to post in here what he did.
Old Aug 26, 2003 | 10:35 AM
theblur98ss's Avatar
I was also curious about the sender/pump. Does it use the stock units or an external pump?
Old Aug 26, 2003 | 11:34 AM
LS1Tech Co-Founder
I'm running an external Weldon fuel pump.
I don't know exactly what Znines modified but something bottomed out in the tank I have. I believe I have the 13 gallon one.
Old Aug 28, 2003 | 03:09 AM
Great thanks john. How was the fit? bolt right up? BTW how is your car coming along?
Old Aug 28, 2003 | 11:23 AM
nbm00ws6's Avatar
I have the 14 gallon in mine. It uses the stock mounting points/straps and uses my stock fuel sending unit. I do run a external fuel pump but use the sending unit for fuel level/gas gauge. The only problem I had was that it hangs down lower than my stock tank and it wouldn't allow me to use my random tech cat-back. So I sold the random tech and bought a loud mouth which fits with no problem.
Tom
Old Aug 28, 2003 | 11:34 AM
Great thanks for the info tom. Good thing I run true dual. BTW is your fuel leve gauge off?
Old Aug 28, 2003 | 12:48 PM
LS1Tech Co-Founder
Yeah is your fuel gauge accurate? I am about to fill it up for the first time.
(My car is coming along by the way)
Old Aug 29, 2003 | 12:25 AM
nbm00ws6's Avatar
Don't think the fuel gauge is 100% accurate but it's close. I never run mine lower than 1/4 tank on the gauge and I add gas from a 55 gallon barrel of Sunoco 104 Unleaded so I'm not for sure how much I add most of the time. I never have filled it up to the top due to the way I vented my tank and me being affraid it might splash out the vent tube.
Tom
Old Aug 29, 2003 | 02:25 PM
Great thanks
