Race Gas?
Old Aug 24, 2003 | 11:39 AM
phenyxTA's Avatar
Default Race Gas?
What is everyone using? Is there anything that won't foul the o2 sensors?
Old Aug 25, 2003 | 01:45 AM
dconn69's Avatar
Default Re: Race Gas?
If you talk to 76 Racing Fuels or VP racing fuels they have like 104-108 Octane Unleaded Fuel
Old Aug 26, 2003 | 02:26 PM
BIGBOS's Avatar
I use 100 now and then, going to tune the car for 93 though...
There is a place by me that sells 110unleaded...
Old Aug 26, 2003 | 11:09 PM
2001CamaroGuy's Avatar
100 - 104 now and then......
Old Sep 8, 2003 | 04:13 PM
dude29662's Avatar
we have a max of 95 at the pump here and its 103 and the track and if you go to the airport you can get 110 but you have to fill up gas cans and tell them its for a plane.
Old Sep 8, 2003 | 04:51 PM
trackbird's Avatar
The aircraft fuel is still leaded. It is marked "low lead", but that is not "unleaded". It is not really the stuff you want for a fuel injected vehicle (it still kills O2 sensors).
Old Sep 8, 2003 | 05:34 PM
BIGBOS's Avatar
Yea, airports stock up on the 100 low lead around here, not good for the 02's....
Old Sep 8, 2003 | 07:06 PM
LS1 Brent's Avatar
My auto tech teacher said they use jet fuel at airports and jet fuel is just diesel fuel??
Old Sep 14, 2003 | 10:27 PM
Pete2k_Z28's Avatar
My understanding of "Jet Fuel" was it was a more highly refined diesel, more like kerosene? Although diesel and kerosene are very close in properties. Keep in mind there are almost as many types of Jet Fuel as there are jet planes, especially in military applications many fuels are specially designed for the application.
I think the gas dude29662 was referring to was regular "Av Gas" for regular piston type engines, as opposed to "Jet" fuel. The "Av Gas" was very popular for a while in dirt bike circles because it's high octane, readily available, and relatively cheap. But Av Gas lacks some of the properties that ordinary gas has, and often causes more problems than it's worth, or so I've heard. Something with the additives I believe but I'm not entirely clear on the subject.
Old Sep 14, 2003 | 11:32 PM
SScam68's Avatar
You guys need to check how the octane ratings are done.
"Jet Fuel", if I am not mistaking, uses a different rating system. Keep in mind this fuel is for high altitude low oxygen environment i.e. high altitude. If I am correct 104 oct jet-fuel is something close to 93-94 oct automobile fuel.
You best bet is just to buy race gas that is sold at the track.
Old Sep 15, 2003 | 02:14 AM
CAT3's Avatar
Restricted User
I have used Trick Racing fuel sold thru 76, 114 yep leaded. Mix a little no problem, use it samn near straight and you need to up your timing lemme tell ya!
No O2 problems as of yet, but I dont plan on continued use of this either.
