Differences between '98 and '99+ fuel tanks?
Old Aug 24, 2003 | 05:59 PM
Slow Z28's Avatar
Default Differences between '98 and '99+ fuel tanks?
Exactly what the title says. Besides the material used. I was looking at the CAS sumped tanks on Speed Inc.'s website, and it lists two different ones, and a big jump in price for the '98 compared to the '99+.
Chris
Old Aug 24, 2003 | 06:58 PM
2000Z28M6's Avatar
Default Re: Differences between '98 and '99+ fuel tanks?
I think the 99+ are larger, they changed with the model years. Read it somewhere. dont qoute me .
Old Aug 24, 2003 | 07:54 PM
slow's Avatar
99+ plastic
98 metal.
Old Aug 24, 2003 | 09:42 PM
Toxic Texan's Avatar
Old Aug 25, 2003 | 07:35 AM
Slow Z28's Avatar
I already knew that part. But if the material is the only difference, then why is there two different prices for the CAS sumped tanks? And if the '99+ were larger, then shouldn't they be the more expensive ones
Old Aug 25, 2003 | 07:55 AM
Reckless's Avatar
Super Moderator
They use a different internal assembly, different filler tube (99-up has a rubber portion and can be disconnected), different setup for charcoal canisters, nearly everything is different.
Old Aug 25, 2003 | 12:20 PM
red ws6 99's Avatar
The lines coming out of the tank are routed in different direction, 98s (metal lines also) the lines point toward the front of the car. 99s (plastic lines) lines point toward the driver side rear wheel. Another words just about everything is different.
Gary
Old Aug 25, 2003 | 12:27 PM
Slow Z28's Avatar
thanks guys. that's what I was looking for! guess i'm stuck paying more damn these '98's
Old Aug 25, 2003 | 12:54 PM
Magnus's Avatar
LS1TECH Sponsor
FYI, I have pics on my web site in the v8 swap section.
Old Aug 25, 2003 | 01:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Z28kid you mean the custom CAS tanks?
I am running one of them, and I had to use a 99 filler neck and gas cap, the stock 98 one will not fit.
I have my entire 98 stock tank around if you wanted a cheap one to sump.
Old Aug 25, 2003 | 05:29 PM
Slow Z28's Avatar
yeah john, i was talking about the aluminum tanks on Speed Inc.'s site. thanks for the offer, but i was hoping to save a little weight with the CAS one, if there is any.
Chris
Old Aug 29, 2003 | 04:12 PM
SuperSport2000's Avatar
john how much do you want for the tank?
Old Sep 3, 2003 | 02:53 AM
95LS1TA's Avatar
I would just sump the metal one. Alot cheaper.
