Racetronics Install Instructions
Old Jul 26, 2008 | 08:56 AM
JVetthead's Avatar
Default Racetronics Install Instructions
Emailed Racetronics 1 week ago and got nothing but a automated response.
Anyone know where else to get install instructions for these pump kits?
Did a search, not much there for a C5
Old Jul 28, 2008 | 11:06 AM
ZL1Killa's Avatar
did you buy the PnP kit or just the pump? what exactly did you buy?
if you bought just the PnP kit, it should be self explanatory
Old Jul 28, 2008 | 12:54 PM
JVetthead's Avatar
Yep, plug and play and yep I am sure I can figure it out.
But, The point is.... What is the big friggin mystery as to the secrecy of giving out damn instructions for a potentially dangerus install and getting no damn reply from the company that sells this stuff??
And I also have a couple of questons like instead of running the power supply all the way up to the alternator can I take it from the battery which is in the rear and closer? Or from my Batt disconect switch that is also in the back end of the car.
Old Jul 28, 2008 | 01:58 PM
Jeff@TotalPerformanceEng's Avatar
1) Disconnect the power from the battery
2) Remove the nut off of the alternator
3) Remove the D.S rear wheel
4) Remove the inner fender (7mm)
5) Remove the 10mm bolts off of the tank shield
6) Remove a few of the front 13mm bolts out of the tank shield.
7) Gently pry the tank shield down about an inch or so. Just so that you have total access.
8) Take the hearness and fish it through your tunnel, above the heat shield, towards the motor. ( Or you can remove it, and wire tie the wires)
9) Fish the connector along the firewall, and route it towards the alternator.
10) Remove the 10mm lower windshield washer tank nut.
11) Install the fuse holder on that stud, and re-install the the nut.
12) Install the jumper wire onto the alternator stud (along with the OEM wire)
13)Route the harness over to the fuel pump.
14) Disconnect the fuel pump connectors, and plug in the Racetronix plugs into the pump.
15) Ground the plug ground to the chassis.
16) Mount the relay and ground in a convenient spot out of the way. Make sure the ground is to the chassis.
17) Zip tie anything that is loose, and button everything up.
18) Re-install the battery cable.
These are NOT the exact instructions. I've just installed soooo many of them, its engrained in my mind.
No, I wouldnt wire it to the battery. Theres to many voltage fluctuations. Your alternator is the BEST possible source.
Hope this helps..
BTW, this is for a C5 corvette..
One last thing. IF by chance your pump does not run, make sure you check the fuse holder that is bolted at the windshield washer tank. Thats the one that blows. It doesnt look like a fuse holder, but it is.
Old Jul 28, 2008 | 02:05 PM
Did you buy the pump to??
Old Jul 28, 2008 | 03:41 PM
JVetthead's Avatar
Thanks for the info Jeff... Yes bought the whole kit with pump for '98 C5
Old Jul 28, 2008 | 04:03 PM
Sigforty's Avatar
try this link. there are pictures as well so it should help you through it.
http://www.cajundude.com/racetronix.htm
Old Jul 29, 2008 | 01:28 AM
Here you go my friend:
http://www.lingenfelter.com/document...ctionsv2.3.pdf
Old Jul 29, 2008 | 06:55 AM
JVetthead's Avatar
Gentlemen... I thank you both, THAT is what I was looking for. I believe the drivers side tank is about the only assembly on these cars I have not been through before...
Thanks again, and no thanks to the mfg
Joe
Old Jul 29, 2008 | 07:59 AM
Sigforty's Avatar
Joe
Glad to help. It is not that bad of a job. Just make sure you have past E on the gas guage. Did mine on E and still had about 4 gallons of gas in the tank.
