99+ front mount regulator with stock lines..
If you are looking at the part on the fuel rail, that is a pulse dampener, not a regulator.
What exactly are you trying to do?
Nate
If you read past your post....everyone else knew what I was talking about...except you.
It is blocked the same as in your picture...we are just going to connect the stock evap line to the return line in the rear and remove the regulator in the tank. Just like you have it but using the stock evap line instead of a new line.
