Which Fuel pump to use with STS Turbo?
Old Aug 18, 2008 | 08:27 PM
Nova29's Avatar
Question Which Fuel pump to use with STS Turbo?
Hey i'm thinkin of buyin an sts kit. its going to come with the 42lb injectors and everything else i need except for the fuel pump. which one should i get? could i get some suggestions plz?
thanks,
Drew
Old Aug 18, 2008 | 09:21 PM
MonochromeSS's Avatar
Lonnie's single, if you even have a thought of going for over 500 hp get the Lonnie's dual. You'll thank yourself later.
Old Aug 18, 2008 | 09:33 PM
Nova29's Avatar
Thumbs up
hey thanks man.
Old Aug 19, 2008 | 07:44 AM
zapp168's Avatar
I ran a racetronix pump with my STS and 60 lb injectors, worked fine.
Old Aug 19, 2008 | 11:13 AM
Nasty N8's Avatar
Really depends on how far you want to take the car. Single pump kit will get you about 500rwhp the dual pump kit will help from there.
Nate
Old Aug 19, 2008 | 05:04 PM
Nova29's Avatar
i really dont plan on ever putting 500 horse to the ground so i'm guessin i'll go with the lonnies/race tronix single.
thanks for the input guys.
Old Aug 20, 2008 | 11:49 AM
NYSS Guy's Avatar
Go with the dual pump setup, you will be thankful. I ran a single with 60# injectors, and was running out of pump at 8 psi. Then I had to pull it all again to add the second pump. With a turbo setup, you can't really overdue your fuel setup.
Old Aug 21, 2008 | 09:20 PM
Yeh... i said the same thing too... You'll always want more power.
Old Aug 21, 2008 | 09:42 PM
LS184's Avatar
lonnies a good guy...and the racetronix pump is real good as well.....im getting 60 psi at idle
