When is dual intank walbros necessary?
Old Sep 2, 2008 | 11:25 PM
green95vert's Avatar
Default When is dual intank walbros necessary?
I'm planning on building a 600rwhp LT1 on spray this winter. When is it necessary to upgrade to dual intank walbros? I have a single right now and it just went out (I ran it outta gas ). Should I just get an external pump? Would a single walbro with the racetronix harness work fine?
Old Sep 2, 2008 | 11:34 PM
rubbersdown's Avatar
If your going to replace it you might as well just drop in a second one. It cant hurt, for $225 have the ability to fuel 1000hp
Old Sep 3, 2008 | 07:37 AM
conan's Avatar
See sig. I'll be puting in a second walbro in the next week or so.
Old Sep 5, 2008 | 02:25 PM
4SFEDZ's Avatar
i wouldnt go any higher than mid 500's. i have a friend with the hotwire kit and put down 59x with a d1sc and hes runnin out of fuel. every car is diff, but why push it!
Old Sep 5, 2008 | 05:40 PM
94lt1m6's Avatar
Are you saying the pump will go out if you run outa gas?
Old Sep 5, 2008 | 11:34 PM
daniel6718's Avatar
problems isnt the power limit its the instant drop youll get from a 200 shot nitrous hit
Old Sep 6, 2008 | 11:54 AM
They don't like to be ran outta gas. Right now I'm considering 2 Walbros or a Bosch 040 pump.
Old Sep 6, 2008 | 12:13 PM
ItsNotStock's Avatar
The reason they don't like to be ran out of gas is because at around a little under a quarter of a tank they start getting hot. Running aftermarket pumps hot for an extended period of time does terrible things to them.
I've seen people with 700hp on the shot with a single pump. You have to take into consideration the voltage the pump is getting as it may attribute to the feeling like the pump is reaching its limits. A simple BAP will fix that.
Old Sep 8, 2008 | 10:22 AM
LT1_Fireman's Avatar
I would go ahead and put both in since you will be on the limit.
Old Sep 8, 2008 | 12:41 PM
99WS7's Avatar
I'd do two if your gonna be in there anyway, piece of mind if you ask me.
4sfedz....that vette in your sig come from TX
