fuelab regulators
Old Sep 4, 2008 | 08:37 PM
rubbersdown's Avatar
Default fuelab regulators
Are the fuelab regulators good with forced induction? I am looking to make around 1000rwhp at the max, but for 99% of the time it will be tuned down to 750-800rwhp, will the fuelab regulator support my fuel needs? If so, I am running -8 fuel line so should I get the regulator with the -6 inlet and use and adapter to step up to my -8 lines? OR get the regulator with the -10 inlets and use an adapted to step it down to my -8 lines?
Old Sep 4, 2008 | 09:07 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I'm nowhere near that power level, or even forced induction for that matter, but my Fuelabs regulator has worked very well on my N/A setup (-6 inlets and outlets). If you get one, I'd get the largest fitting sizes they offer and go from there. From what I can tell, they are a good company, and when I called with a question like this, they were very friendly on the phone. You might try giving them a call.
Old Sep 4, 2008 | 09:23 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Be aware many -6 regulators are for sport compact applications which are designed for less return flow & may not be happy with a huge pump. Check their capacity first.
A -6 line to the regulator is all you need.
Keep in mind the regulator only has to return the fuel to the tank, not flow all the fuel through it to feed the motor.... but a huge race pump flows a lot of fuel when the motor is not using it.
Most regulators only have an approx 1/8" orifice to return the fuel through them to the tank.
Old Sep 4, 2008 | 10:50 PM
I will be running twin 255lph in tank walbros and have seen many turbo guys run 800-1000hp with a -6 return line, and those exact pumps.
