do i need larger injectors for my setup?
Old Sep 25, 2008 | 04:14 PM
wilwhite2kss's Avatar
Default do i need larger injectors for my setup?
My new setup is tfs 215's, custom cam, harland sharp 1.7 rr, fast 92/92 asp ud pulley. Not sure if i should get larger injectors or not, but if i do i want to do it before i tune the car.and if i do need larger injector, will my fuel pump be ok?
Old Sep 27, 2008 | 12:04 PM
Pro Mouse's Avatar
Your stock 28# injectors will be enough assuming you have Stock cubes
Old Sep 27, 2008 | 12:10 PM
thanks, is there any horsepower to be gained by adding more fuel with larger injectors?
Old Sep 27, 2008 | 12:13 PM
Pro Mouse's Avatar
I don't think so,but let some of the other guys chime in.I had my MTI H/C set up and 90/90 set up, my 28#er's still had 15% duty cycle left in them.
Old Oct 7, 2008 | 12:40 PM
anybody else chime in?
Old Oct 13, 2008 | 07:30 AM
Kurtomac's Avatar
you need new ones....you have a 2000...they only have 26 lbers from the factory...Try a set of FAST 36lbers....same injectors that came in the GM ASA cars so you KNOW the specs to input in your Injector tables or your tune....Or a set of SVO 30s...lots of guys have success with those
Old Oct 13, 2008 | 11:53 AM
ZL1Killa's Avatar
I would grab some 36# injectors or higher. I would not go higher then 42# injectors unless you plan on pushing past 500RWHP.
I have been around and around with injectors.... I would buy some more and truthfully I don't know why they gave our cars such small injectors
Old Oct 13, 2008 | 02:20 PM
FICINJECTORS's Avatar
I would indeed recommend going larger, we have a good deal right now on the old style and new style SVO 30's, as well as any other ones you would like.
Old Oct 14, 2008 | 09:53 PM
riceburnerZ28's Avatar
ficinjectors how much would u charge for 8 42# injectors ?
Old Oct 14, 2008 | 10:09 PM
We have several options in the 42lb variety.
We have New Bosch Design II's (old style SVO) for $49.95 each
We have new Lucas 42lb for $42.95 each
We have our rebuild Bosch Design II's for $239.95 for the set of 8
And our rebuilt 42lb Bosch Design III's for $239 for the set of 8 (I recommend these)
42lb is a lot of injector for a V8. what kind of CHP do you have?
Old Oct 14, 2008 | 11:12 PM
Yes, all injector sets we sell are flow matched, with Viton o-rings installed
Old Oct 15, 2008 | 11:48 AM
JScamaro's Avatar
With that setup I would definitely upgrade the injectors and pump.
Old Oct 15, 2008 | 03:17 PM
What does chp mean? sorry newb !
Old Oct 15, 2008 | 03:24 PM
What size injectors do you recommend ? My engine is built to handle 500hp but I don't have the heads or intake ported yet. It should not be hard to exceed at least 400hp...or am I wrong ?
Old Oct 15, 2008 | 03:46 PM
dankl's Avatar
Upgrade your entire fuel system. I would start with the fuel pump. Stock won't hang on much past 5500 RPM's with the stock system. If your making power, get a better fuel pump. Good idea to do that and the 36# injectors.
Old Oct 15, 2008 | 08:03 PM
ZL1Killa's Avatar
grab you a 42# injector and a fuel pump rated 255 or 340
Old Oct 15, 2008 | 09:51 PM
I agree
crank Horsepower
wheel HP or crank HP?
Old Oct 16, 2008 | 11:44 PM
sidewayz28's Avatar
I went the "cheap" route and dont regret it ONE BIT. i bought some low mile used 2003/4 Cobra injectors which are 39#ers. I then bought the adapters from Casper and it cost me a total of under $300... I dont know, you tell me.. i get enough fuel w/ a racetronix kit and 39#ers
Old Oct 17, 2008 | 06:44 AM
How is that the "cheap" route? I have the Design III 42's for $239 flow matched with o-rings and a 3 year warranty?
Old Oct 17, 2008 | 01:55 PM
sidewayz28's Avatar
ummm it was cheap before you joined this website smart one! i probably spent the same cash asyour new injectors.. big whoop
