wtb: 9" rear
Old Oct 30, 2008 | 09:56 PM
promaro396's Avatar
Default wtb: 9" rear
im lookin 4 a 9" my wife is gonna buy it for me for christmas i would like to find one assembled with axles spool breaks center section etc.. thanks. if its narrowed thats fine to....
Old Oct 31, 2008 | 12:30 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
you looking for new or used? i can hook you up with a sweet setup if you want a new one. if used is what you are looking for, i *may* be selling the fab rearend that is currently in my car. not sure yet though.
Old Oct 31, 2008 | 12:05 PM
Steve Burger's Avatar
LS1TECH Sponsor
Can you be more specific on what you want? we can get Moser or one of our fabricated housings.
Old Oct 31, 2008 | 02:45 PM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=148
Check out our prices at the above link, and these rears are shipped out two days after the order is received. Bob
Old Oct 31, 2008 | 02:46 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
i have a used, but super clean housing w/ torque arm mount
Old Nov 1, 2008 | 10:58 PM
promaro396's Avatar
what i am lookin 4 is a 9" narrowed 5" on each side so i can run 15x10 w/3.5" bs ..456 gear with full spool and a nodular or aluminum center section.. disc breaks.. thanks for the replys.. im gonna c what used stuff i can find before i start lookin @ new stuff..
Old Nov 2, 2008 | 12:48 PM
LS1TECH Sponsor
5" per side is doable but a lot more work. YOu need to redo the LCA brackets. We can do this but is is a little more $$. This would definately be a Fabricated housing. The Moser will not work.
Old Nov 2, 2008 | 03:36 PM
promaro396's Avatar
steve can u help me understand why it wil be more work.. im confused.. i was thinkin if a 10" 7.5 bs wheel wil fit under a stock rear and a 10" 5.5 bs wheel wil work with a 3" narrowed rear then a 10"3.5 bs wheel should be the same diff with a 5" narrowed rear.. right.. in all three positions the wheel should never move meaning if a offset control arm should work.. i just dont understand why the control arm bracket needs to be redone..leme now man thanks alot for ur help..
Old Nov 3, 2008 | 07:32 AM
LS1TECH Sponsor
On a stock length rear there is not 5" between the housing end and the LCA mounting bracket. We do have a narrow LCA bracket and it is an option on the housing. It does away with the offset bushings. You may need to massage the front mounts as well. 4" is easy. THe last inch requires a lot of work under the car to get all of the suspension pickup points on the housing to work.
Measure your stock housing 5" in and you will see that you start to get into the mounts.
