Pros Vs Cons When it comes to Narrowing a Rearend?
You can only narrow it x amount without changing the rim offset without minitubbing the car, but if offset isn't a concern because you are buying new rims, I would narrow it so that you can run a common offset wheel, like a 5.5 backspace or whatever so that your rim choices are better.
