What series carrier does Moser use?
I am fixing to order a new set of gears for my Moser 12 bolt and am needing to know if it has a 3 or 4 series carrier. The rearend came with 4.10s so I'm not sure which it would be.
Re: What series carrier does Moser use?
Well I found out the rest of the specs on the rearend, hopefully this will help. I really need to find out so I can get rid of the horrible whine.
*Moser F-Body 12 Bolt Rear End, complete bolt-in with posi. Comes standard with 30 spline Eaton posi, Mosier Eng. Custom Axles, Pro-Street Gears, Pinion Yoke and Chrome Cover
*ABS setup for 3 channel
*Upgrade to 33 spline US Gear/Eaton Posi
*4.10 gear ratio
*Standard 12mm wheel studs
*4.10 gear ratio
